Hansje
Mar 08, 2018Aspirant
mysqli_real_connect(): (HY000/1045): Access denied for user 'root'@'localhost' (using password: NO)
I cannot set up a database in mysql using phpmyadmin. Both apps are installed on the NAS. Occarding to the documentation a configuration file in mysql needs to be installed. But there's no directory ...
Hansje
The second command is not accepted. Systems replies with "system error 53. Can't find the networkpath."
First nothing happened, but after enabling SSH the first command worked but the second failed.
Is there somthing I forgot?
Mar 09, 2018Guru - Experienced User
SSH isn't needed for either command.
Common causes for system error 53:
- SMB client is not enabled on the PC (perhaps because the network is classified as private)
- SMB service is not enabled on the NAS
- NAS workgroup doesn't match the PC workgroup
- Command is mistyped
- Admin user on the NAS still uses the default password
- NAS data volume name isn't data
- You have a share name or NAS account that matches the volume name (bad idea btw).
If it's one of the first three, then you won't have any SMB access to the NAS at all.
If ssh is available, you can find the config file using linux shell commands (look in /apps first). If you want to use notepad++ to edit it, then you can copy it to a share on the NAS, edit it from windows, and then copy it back to the proper location.
