voidness's avatar
Jan 04, 2016
Trasmission stopped working ReadyNAS 104 firmware 6.4.0
All of the sudden my Transmission stopped working checking chkconfig, transmission isn't enable so I tried to but still getting error.
root@nas:~# chkconfig transmission on
insserv: Service networking has to be enabled to start service transmission-daemon
insserv: exiting now!
/sbin/insserv failed, exit code 1
starting manually exit 0
oot@voidness-nas:~# service transmission start
Starting bittorrent client transmission-daemon...
Starting bittorrent client transmission-daemon succeeded
however its not working, as I cannot connect to the gui using a browser, further checking with netstat and telnet, the system is not listening on 8181.
root@voidness-nas:~# telnet localhost 8181
Trying ::1...
Trying 127.0.0.1...
telnet: Unable to connect to remote host: Connection refused
this is really weird why is it asking for networking ? and why all of the sudden it stopped working when i have not made any changes ?
please help
  • I reinstalled the same firmware and reinstall transmission throught the apps page and everything is fine now. Thanks heaps for you help. This can be closed
    • voidness's avatar
      voidness
      Guide
      I am running 2.82-1
      apt-get install transmission=2.82-1
      • mdgm-ntgr's avatar
        mdgm-ntgr
        NETGEAR Employee Retired
        So you installed it that way rather than using the app from apps.readynas.com ?
        Can you send in your logs (see the Sending Logs link in my sig)?
        Do you have a backup of your data?
