sylvainp
Aug 18, 2022Aspirant
Need help for shared permission and dual redundancy
Hi all, I have been using my ReadyNAS Pro (6 bays) for many years and upgrade (CPU, Memory, and OS) Now using OS 6.xx Recently I lost all my volume (all red) probably a corrupt system files or Netda...
Aug 18, 2022Guru - Experienced User
sylvainp wrote:
What could cause the backup software to not have access and write on my shared folder if the anonymous access is not enable ?
It sounds like the backup software is giving the NAS a username that doesn't exist on the NAS.
sylvainp wrote:
Can I change to dual redundancy from a X-RAID 5 mode without restart everything ?
If you switch to flexraid you should be able to add a disk for redundancy.
- sylvainpAug 18, 2022Aspirant
When I try to execute the backup I have a prompt to enter username and password.
So I enter "Admin" and my password : The same I use to access the NAS Admin Page.
This software only work in anonymous access which I don't want to use.
Looks like I need to use SMB Legacy Windows Discovery to make it work. I think this is SMB 1.0 compatibility mode.
I read some concern about using SMB 1.0 is vulnerable for privacy and security issue.
Very strange this software need the SMB Legacy Windows Discovery to work.
- StephenBAug 19, 2022Guru - Experienced User
OS 6 supports SMB 3. Are you connecting using the NAS hostname, or are you using the IP address?
Is the NAS admin password still set to the default value of password?
