Digsy's avatar
Digsy
Samba share access permissions not making sense
I just noticed that access permissions for SMB shares on my ReadyNAS102 don't seem to be working.
When I set up my RN102 sereval years ago I was a bit lazy and just set up all my shares as read/write for any user with anonymous access allowed. It's juts me using it, so no biggie. However later I added a home-made CCTV system which uses FTP to upload images from cameras  which are them viewed using HTTP on a small website whch is hosted on the NAS. For this I created a new share called "CCTV" and user accounts for each camera and a master account for the viewer, which all worked just fine.
Recently, however, I decided I watned to be ablet o download the images from the camera en masse using my Windows 7 PC, so I "simply" added SMB access to the share and attempted to connect to it, and.... got a bog fat "access denied" message.
In fact, I canot access this share over SMB even if I set it to alllow Anonymous Access. Ahat is even more weird, if I create a new share just for testing, turn SMB access on and set it to only allow my "CCTV master user" it still allows any-old-one to access it.
In short it seems like any SMB permissons that I try to set from some point in time prior to now are being completely ignored. Old shares I cannot add permissions, and new shares I cannot restrict permissions.
Any thoughts, anyone?
  • Digsy wrote:
    The CCTV share is the only share that I want to require a username and password for, but when specify this username in Network Access and I supply credentials for it when I try to connect, it doesn't work unless I use the command line.Windows won't accept my username and password as valid, but the command line will.
    Obviously this is a Windows issue.
    If you entered the credential in the Windows Credential Manager, then you shouldn't be needing to enter the username at all.  If you also entered the password there, you shouldn't be needing to enter that either.
    Are you entering \\nas-ip-address\sharename in the file explorer address bar to access the share?
    One thing to keep in mind - Windows only allows one set of credentials per machine at a time.  And if you first access the NAS w/o a credential, Windows will still use one - it defaults to using the Windows Login.  You can clear that using the net use * /delete /y command.  So perhaps just try that command, and then see if the file explorer will take your credential.
  • StephenB's avatar
    Without more details on your settings, we can't offer much advice.
    There are File Permissions (which apply to all protocols - in your case both FTP and SMB), and there is Network Access, which needs to be set up separately for each protocol.  Both need to be set up to allow access, but either can result in denied access.
    My general advice here is to set up the File Permissions so that everyone can access the underlying files.  Then control access with Network Access alone.  That is generally simpler.
    In your specific case with denied access.  I suggest starting by resetting the file permissions for the share, and see if that allows you to access the files over SMB.  Check the box next to "Grant rename and delete privileges" before you click on the reset control. The CCTV system might be using very restrictive file permissions when it creates the files - resetting the permissions will change that so they match the configuration on the share.
    For your test share, try creating a test account, and put it in test group (not users).  Then try enabling read-only network access to the test group, but no access to the users group.   Also set read/write access for the test account, but not for the CCTV account.  Then see if that allows access when you access the NAS with the test account credentials, but denies access when you use the CCTV account credentials.
    You do need to be careful when testing share access with Windows, as it often isn't applying the user credentials that you think it is.  So if you are using Windows, then I suggest testing access directly with the windows command line.  You launch this by typing CMD in the windows search box.
    Test access to a share by entering
    net use t: \\nas-ip-address\sharename /user:username password
    using actual values instead of the blue placeholders of course.  Be careful on the typing - particularly with spaces and the slash directions.
    The first command terminates any open SMB sessions in the PC, the second attempts to mount the NAS share as drive letter T.  If you want to test with multiple NAS accounts, make sure you enter the both commands every time.
    • Digsy's avatar
      Digsy
      Thanks for the detailled reply. I sem to have fixed this now but I still don't understand how / why.
      When gong into the File Access section for the share, I noticed that although the folder owner name was set to my master CCTV account, there was no tick against "Folder Owner" for either Read nor Read/Write access, although Rear/Write was ticked for "Folder Group". Bear in mind that this was working fine for HTTP (reading via the web viewer) and write (via FTP) but not for SMB.
      I guess I had accidentally locked my master CCTV account out by granting neither read nor read/write access, but I don't understand why SMB should behave differently to FTP or HTTP where this setting is concerned.
      Also, it seems (as you suggest) that I can only map this particular share from the command line and not from inside Explorer - again, no idea why.
      As I have a solution I haven't done all your troubleshooting steps, but here are my settings for this share:
      Network access:
      For SMB:
      Admin (group): Read / Write
      Admin (user): Read / Write
      CCTV master (user): Rear / Write
      No others ticked
      For FTP:
      Cameras (group): Read / Write
      No others ticked
      For HTTP:
      No others ticked
      File access:
      Folder Owner: CCTV master
      Folder Group: Cameras
      "Grant rename and delete...": ticked
      Everyone (group): Read/Write
      Folder Owner (user): Read/Write
      Folder Group (group): Read/Write
      Admin (group): Read/Write
      Admin (user): Read/Write
      No others ticked
      • StephenB's avatar
        Likely the PC isn't using the correct credentials.  Try running the windows credential manager, and delete any existing credentials for the NAS.  Then add a credential, using the NAS account you wish to use.
        Note if you use both NAS hostname and the NAS IP, you will need two credentials - one for each.
ProSupport for Business
