christerj77
May 04, 2013Aspirant
Need help with ftdi_sio drivers
Im trying to get my rfxtrx433 usb to work with my readynas ultra 2 with os 6 installed but i cant understand how to install/compile the ftdi_sio drivers, anyone can help me with this?
Max_1968
Oct 22, 2013Aspirant
Hi,
I'm trying to run openhab (http://www.openhab.org) on my Readynas Ultra 4 running RAIDiator 4.2.24, and one of the things needed for this is the FTDI driver for the Plugwise (http://www.plugwise.com) energy monitoring sockets.
I've followed the steps proposed by chirpa using the GPL sources from http://www.downloads.netgear.com/files/ ... WW_src.zip, and both the build and the install_modules seem to work fine. However when trying the modload I'm getting the same message as chirpa did:
I guess this is due to the missing ReadyNAS .configure file in the GPL sources (at least I couldn't find it). Can someone please help me on this / has tried this on 4.2.24 as well ?
Thx,
Max
modprobe: can't load module usbserial (kernel/drivers/usb/serial/usbserial.ko): invalid module format
Thx,
Max
