Tcurley
Jul 20, 2020Aspirant
Netgear Pro Pioneer RNDP600E-100NAS not powering up
When I power on the RNDP600E-100NAS the display lights up with ReadyNas and thats it. The large fan (top rear) is on, but not the lower fan. The Ethernet ports dont even flicker. I replaced the po...
Tcurley
Jul 30, 2020Aspirant
Thank you for your reply and answers. Does anyone have a wiring diagram for reconnecting a Seasonic SSP-300SFB power supply?
Sandshark
Jul 30, 2020Sensei
You just plug it in, the connections on the 6-bay legacy units are standard ATX12V. You'll need an extension for the 24-pin ATX connector and either a splitter for the 4-pin Molex power to the backplane or to use the 90° ones from the old supply to add them in place of SATA ones.
