jpass022
Apr 17, 2019Luminary
Netgear readynas and docker
ReadyNAS 4312
I tried to install Docker version docker-cli-rnapp_17.12.1-ml1_amd64 and a few older versions and I keep getting an error "Cannot install application docker-cli-rnapp."
From lo...
- Apr 17, 2019
There was an issue with the linux-image-extra versioning on the 6.10..0-RC2 build.
Try updating the ReadyNAS to the release build:
OOM-9
Apr 17, 2019NETGEAR Expert
What firmware version are you running?
It requires linux-image-extra. That package should be available on all public releases, but I would need to confirm.
You could send us your logs so we can see in more detail what the app error is reporting.
jpass022
Running firmware 6.10.0(RC2)...
I sent the log.zip file...
- OOM-9Apr 17, 2019NETGEAR Expert
- jpass022Apr 17, 2019Luminary
I installed OS 6.10.0 Hotfix 2, this fixed my Docker, Portainer, and Kernel Plus install issues..
Thanks OOM-9
