ashfakjs
Dec 09, 2020Guide
Netgear readyNAS RN42800
Dear All, I'm getting continous notification from Netgear NAS storage regarding Virus, actually it is a Package file for MAC operating system, but unfortunately Netgar Virus protection is detecting ...
Marc_V
Dec 10, 2020NETGEAR Employee Retired
Welcome to the Community!
No option under the GUI that can do that at the moment. It might be of help if you disable the AV on the NAS.
Accessing via SSH this might be possible but not supported
HTH
ashfakjs
May 19, 2021Guide
Marc_V Thanks for replaying me & can you please let me know how to update AV using SSH.
Best Regards
Ashfak
- StephenBMay 19, 2021Guru - Experienced User
I don't know of any way to tell clamav to ignore a particular file. But you can tell it to exclude one or more directories from a scan by modifying clamd.conf.
Details are in https://linux.die.net/man/5/clamd.conf:
ExcludePath REGEX Don't scan files and directories matching REGEX. This directive can be used multiple times.
- SandsharkMay 19, 2021Sensei
The other option is to put the file in an encrypted zip, VeraCrypt, or similar file to hide it from the antivirus. Putting it in a non-encrypted file won't (or at least shouldn't) do the job.
