ashfakjs
Dec 09, 2020Guide
Netgear readyNAS RN42800
Dear All, I'm getting continous notification from Netgear NAS storage regarding Virus, actually it is a Package file for MAC operating system, but unfortunately Netgar Virus protection is detecting ...
ashfakjs
May 19, 2021Guide
Marc_V Thanks for replaying me & can you please let me know how to update AV using SSH.
Best Regards
Ashfak
May 19, 2021Guru - Experienced User
I don't know of any way to tell clamav to ignore a particular file. But you can tell it to exclude one or more directories from a scan by modifying clamd.conf.
Details are in https://linux.die.net/man/5/clamd.conf:
ExcludePath REGEX Don't scan files and directories matching REGEX. This directive can be used multiple times.
- SandsharkMay 19, 2021Sensei
The other option is to put the file in an encrypted zip, VeraCrypt, or similar file to hide it from the antivirus. Putting it in a non-encrypted file won't (or at least shouldn't) do the job.
