UberNewf
Apr 14, 2008Aspirant
Newbie question: Remote Shutdown...
I run Windows OS on all my machines. I'd like to be able to dbl-click an icon to remote shutdown my ReadyNas x6, with a simple "Are you sure?" prompt. This will save me having to log into the (slow) U...
chirpa
Apr 14, 2008Luminary
Get curl for Windows, then make a batch/cmd file to run a curl line that will trigger a shutdown.
Curl-win32: http://curl.haxx.se/latest.cgi?curl=win32-ssl-sspi
Remote Shutdown a ReadyNAS: viewtopic.php?p=94750#p94750
