UberNewf
Apr 14, 2008Aspirant
Newbie question: Remote Shutdown...
I run Windows OS on all my machines. I'd like to be able to dbl-click an icon to remote shutdown my ReadyNas x6, with a simple "Are you sure?" prompt. This will save me having to log into the (slow) U...
freewuns
Aug 24, 2009Aspirant
Hi Guys,
Trying to figure this Curl out. Downloaded as per the link but trying to find the installation instructions seems elusive. I want to do an unattended shut down of an NVX by an XP machine on the network, and from what I read, Curl is what I need. The unattended shutdown will only be initiated under certain conditions by the XP machine so using the NVX power schedule is no good.
Any tips on installation etc of the linked software would be much appreciated.
Thanks :D
Thanks :D
