UberNewf
Apr 14, 2008Aspirant
Newbie question: Remote Shutdown...
I run Windows OS on all my machines. I'd like to be able to dbl-click an icon to remote shutdown my ReadyNas x6, with a simple "Are you sure?" prompt. This will save me having to log into the (slow) U...
freewuns
Aug 24, 2009Aspirant
Thanks for that......I pasted the shutdown and turnoff only command (with my IP) into address bar of Internet Explorer and it requested my username and password. When I entered UN & PW browser window returned the following and the NAS shutdown.
<?xml version="1.0" encoding="UTF-8" ?>
- <payload>
<status>success</status>
<debug />
- <log_alerts>
<message>Please close this browser session and use RAIDar to reconnect to the device after it is powered back on. System powering off... [Tue Aug 25 08:48:40 EST 2009]</message>
</log_alerts>
- <normal_alerts>
<message>NO_ALERTS</message>
</normal_alerts>
</payload>
I am a mega newb at this stuff and you pretty much lost me at "Tamper Data" lol I need to run this from a batch file on the XP machine if at all possible with no user input.
Thanks hearps for your time.
- <payload>
<debug />
- <log_alerts>
</log_alerts>
- <normal_alerts>
</normal_alerts>
</payload>
