UberNewf
Apr 14, 2008Aspirant
Newbie question: Remote Shutdown...
I run Windows OS on all my machines. I'd like to be able to dbl-click an icon to remote shutdown my ReadyNas x6, with a simple "Are you sure?" prompt. This will save me having to log into the (slow) U...
jaholstein
May 15, 2012Guide
I had a similar problem with a missing libeay32.dll and CHIRPA said
Try this curl, should work without DLL issues.
http://curl.haxx.se/gknw.net/win32/curl ... in-w32.zip
and indeed ... it works great.
Jim 5/15/2012
Jim 5/15/2012
