McGarnagle
May 09, 2017Aspirant
NZBGet unpack not working
Hi I currently have NZBGet set up so that all new downloads are downloaded into an "Incomplete" folder. I've then set NGBGet so that complete downloads are moved to a "Complete" folder, with sub...
JennC
May 10, 2017NETGEAR Employee Retired
Hello McGarnagle,
You might want to see this topic where a user of this app gave some tips.
JBDragon1
May 14, 2017Virtuoso
I'm going tohave to try this myself as soon as I can so that NZBGet will auto update as it should. It would be better if it was all setup with a simple DEB file as work, but I guess I can go and manually do it.
