rockingcf's avatar
rockingcf
NZBGet Unrar Issues
Hello Everyone, I have seen this unrar Error 64 resolved before but the posts are a couple years old. I am having the issue currently in NZBGet with a ReadyNas 102 running current firmware. Wondering if anyone could give me some quick help on this. Hoping not to have to flatten the device and start from scratch if I can avoid it. Appreciate anyone's help.
  • Try entering apt-get install unrar
    It's already installed of course, but that command should upgrade it to a newer version.  I tried a clean install on my RN526 (running 6.9.2) and I got a newer version (5.x if I remember correctly).
    Do remember to log in as root - the NAS will accept logging in as admin, but you don't want to do that.
  • StephenB's avatar
    Maybe go in with ssh, and see what version of unrar is installed.
    • rockingcf's avatar
      rockingcf
      ahh ssh , my weakness unfortunately . I am unsure how to ssh into the device ( I should say I have a terminal program just don't know the commands )
      • StephenB's avatar
        With terminal (on a mac) you'd enter ssh root@nas-ip-address (using the real IP address of course) and then enter your NAS admin password.  After that, just type unrar after the # prompt.  The response will include the software version number, as well as a list of commands.
ProSupport for Business
