rockingcf
Mar 10, 2018Aspirant
NZBGet Unrar Issues
Hello Everyone, I have seen this unrar Error 64 resolved before but the posts are a couple years old. I am having the issue currently in NZBGet with a ReadyNas 102 running current firmware. Wondering...
- Mar 12, 2018
Try entering apt-get install unrar
It's already installed of course, but that command should upgrade it to a newer version. I tried a clean install on my RN526 (running 6.9.2) and I got a newer version (5.x if I remember correctly).
Do remember to log in as root - the NAS will accept logging in as admin, but you don't want to do that.
rockingcf
Mar 11, 2018Aspirant
ahh ssh , my weakness unfortunately . I am unsure how to ssh into the device ( I should say I have a terminal program just don't know the commands )
Mar 11, 2018Guru - Experienced User
With terminal (on a mac) you'd enter ssh root@nas-ip-address (using the real IP address of course) and then enter your NAS admin password. After that, just type unrar after the # prompt. The response will include the software version number, as well as a list of commands.
- rockingcfMar 11, 2018Aspirant
Thank you. It says 'unrar 0.0.1' when i type in unrar -V
- StephenBMar 12, 2018Guru - Experienced User
- rockingcfMar 20, 2018Aspirant
Apologizes I just took a look at this last night. This was very helpful and resolved my problem, appreciate your support.
