trasixes
Dec 28, 2015Tutor
Script to automatically unrar files downloaded by Transmission?
Hi folks, I am new here and I really hope this is the right place for this.
I was given an RN102, and I have found it fits my needs almost perfectly. I have the Transmission add-on installed and working. I have it set to watch a directory for new torrents and download them. The only thing missing is a way to have rar files auto-extract. I have used unrar via SSH as a test, and found the extraction speed to be satisfactory.
I know Transmissíon has the ability to run a script on download completion - is there a working script that could be triggered by Transmission on download completion to run unrar on the files?
As I said, the unit in question is an RN102 with 6.4.1 firmware. I would greatly appreciate any help, advice, or nudge in the right direction.
To anyone looking for the same solution, here is where I ended up.
I switched from Transmission to Deluge Torrent which comes with it's own extraction plugin. Deluge seems faster, and generally more consistent. RAR/ZIP files are automatically extracted as downloads complete.
Overall, this solution is perfect for me, and exactly what I needed!
- trasixesTutor
75 views, alas no replies.
I've enabled the following in the Transmission settings.json, and tried many different unrar scripts created to run after a torrent completes in Transmission, but I get absolutely nothing.
"script-torrent-done-enabled": true, "script-torrent-done-filename": "/path/scriptname",Anyone able to help? This is quite literally the last step to perfection, in my case.
- trasixesTutor
