trasixes
Dec 28, 2015Tutor
Script to automatically unrar files downloaded by Transmission?
Hi folks, I am new here and I really hope this is the right place for this. I was given an RN102, and I have found it fits my needs almost perfectly. I have the Transmission add-on installed and ...
- Jan 15, 2016
To anyone looking for the same solution, here is where I ended up.
I switched from Transmission to Deluge Torrent which comes with it's own extraction plugin. Deluge seems faster, and generally more consistent. RAR/ZIP files are automatically extracted as downloads complete.
Overall, this solution is perfect for me, and exactly what I needed!
trasixes
Dec 31, 2015Tutor
75 views, alas no replies.
I've enabled the following in the Transmission settings.json, and tried many different unrar scripts created to run after a torrent completes in Transmission, but I get absolutely nothing.
"script-torrent-done-enabled": true,
"script-torrent-done-filename": "/path/scriptname", Anyone able to help? This is quite literally the last step to perfection, in my case.
- trasixesJan 15, 2016Tutor
