McGarnagle
May 09, 2017Aspirant
NZBGet unpack not working
Hi I currently have NZBGet set up so that all new downloads are downloaded into an "Incomplete" folder. I've then set NGBGet so that complete downloads are moved to a "Complete" folder, with sub...
JennC
May 10, 2017NETGEAR Employee Retired
Hello McGarnagle,
You might want to see this topic where a user of this app gave some tips.
McGarnagle
May 15, 2017Aspirant
Hi JennC.
Unfortunetely that link didnt help (unless i've missed something). The NZBGet app works for everything except for unpacking. This is the thing i need to solve.
- JBDragon1May 20, 2017Virtuoso
I'm using a version, 17.1 I was able to easily install as it was a DEB version. So it Unpacks great for me. I've been using it for a while. But it can't Update through the software. Not that having the newest version matters to much. This is the version I'm currently using and it works just fine for me.
https://github.com/Mhynlo/nzbget/releases/tag/v17.1-6
After it's installed, it show up with any other App's on your NAS that's installed. It will show there what the Default login name and password is. Use those to get on and then you can change it to whatever you want.
Just finished getting Radarr installed on my NAS to go along Sonarr. Both take some effort to get installed and to auto bootup. You have to SSH into the NAS to get installed and running. Both are working with NZBGet just fine and auto unpack using the version I have listed above. These 2 app's don't show up in the App's section on the NAS since they were installed in SSH and not as a DEB file.
- mvranaJun 17, 2017Tutor
What instructions did you use to install Radarr?
