McGarnagle
May 09, 2017Aspirant
NZBGet unpack not working
Hi I currently have NZBGet set up so that all new downloads are downloaded into an "Incomplete" folder. I've then set NGBGet so that complete downloads are moved to a "Complete" folder, with sub...
McGarnagle
May 15, 2017Aspirant
Hi JennC.
Unfortunetely that link didnt help (unless i've missed something). The NZBGet app works for everything except for unpacking. This is the thing i need to solve.
JBDragon1
May 20, 2017Virtuoso
I'm using a version, 17.1 I was able to easily install as it was a DEB version. So it Unpacks great for me. I've been using it for a while. But it can't Update through the software. Not that having the newest version matters to much. This is the version I'm currently using and it works just fine for me.
https://github.com/Mhynlo/nzbget/releases/tag/v17.1-6
After it's installed, it show up with any other App's on your NAS that's installed. It will show there what the Default login name and password is. Use those to get on and then you can change it to whatever you want.
