shen
Apr 13, 2014Tutor
OS 6.1.7 - Bittorrent Sync does not start anymore
I installed Bittorrent Sync in late 2013 and in ran without problems. Yesterday I updatet my ReadyNAS 312 to OS 6.1.7 and BTSync fails to start. Version Installed: 1.2.93 If I click the "on swi...
GrilledSandwich
Apr 15, 2014Aspirant
Hello Super-Poussin.
I have no idea how to use Linux so I need some help. I have the exact same issue that Shen is having with my ReadyNAS 314 after I upgraded to firmware 6.1.7.
Is it possible for me to download the updated packages from BT and just install into linux? Your version which is on the Netgear apps site is quite old and one of the staff at BT recommended I upgrade from 1.2.93 to 1.3.87 to see if it helps.
Could you assist at all as I love BT SYNC and I use it daily.
Thanks,
GrilledSandwich.
Thanks,
GrilledSandwich.
