shen's avatar
shen
Tutor
Apr 13, 2014
OS 6.1.7 - Bittorrent Sync does not start anymore
I installed Bittorrent Sync in late 2013 and in ran without problems.
Yesterday I updatet my ReadyNAS 312 to OS 6.1.7 and BTSync fails to start.
Version Installed: 1.2.93
If I click the "on switch" in the apps list, it says
Application failed to initialize
22002010000
Any furter information required I can help you with? :-)
Stefan
  • Hi
    For the Arm based units (I have a 314) you can download the latest Linux x86_64 which just contains the btsync binary. Upload this and put it in place of the /apps/btsync/bin/btsync binary and it will work.
    Hope this helps.
    -Barry
  • I'd be happy for any solution which works so if there is a way to create one or give instructions I'd be very happy to hear and naturally happy to donate to the cause :)
  • Hi All.
    I downloaded BTSYNC 1.3.87, copied it over via SSH to the opt directory, changed the permissions to execute and tried to run ./btsync but it says it "cannot execute binary file".
    How can I install the latest BTSYNC?
    GrilledSandwich
  • You my friend are a flippin star! It works!
    Next time I need to be certain a firmware update wont kill all my apps!
    Now to try and get sickbeard, couchpotato 2 and sabnzbd working again. Sigh.
    Thanks Super-Poussin for your help.
  • Super-Poussin,
    While at it you wouldnt happen to have copies of the latest version of the following would you:
    Sickbeard (cant find debian download of 2.4.0)
    Couchpotato (cant find debian download of 2.4.0)
    Sabnzbd+ (cant find debian download of 2.4.0)
    Plex Media Server ( latest version is broken when installing from PLEX site)
    Qbittorrent (3.1.9 isnt available for debian on their site?)
    Happy to pay you a few dollars each app to help get them working.
    Thanks!
ProSupport for Business
