getyogrooveon
Apr 12, 2014Aspirant
OS 6.1.7 broken some addons
Installed OS 6.1.7 on my RN102 this afternoon. Since installing this update Sab 07.1.13 will no longer start up (Sab originally installed from the App section of Frontview) . Click the on button resu...
getyogrooveon
Apr 13, 2014Aspirant
Hi Xeltros, thanks for the response
Seems there is no PID file for Sabnzbd anymore (or for DDClient also)?
Checking in the location from the Sab log file (/var/run/sabnzbd/) the folder there is also empty. I assume that the OS upgrade has removed this critical file?
Running your second command:
Which appears to be the same as yours?
Again, thanks for your help, any suggestions greatly appreciated. Seems like this upgrade is casuing other issues with addons also? http://www.readynas.com/forum/viewtopic.php?f=153&t=76009
-rw-r--r-- 1 root root 5 Apr 12 18:31 apache2.pid
-rw-r--r-- 1 root root 4 Apr 12 18:30 brokerd.pid
-rw-r--r-- 1 root root 5 Apr 12 18:30 crond.pid
-rw-r--r-- 1 root root 5 Apr 12 18:31 minissdpd.pid
-rw-r--r-- 1 root root 5 Apr 12 18:30 nmbd.pid
-rw-r--r-- 1 root root 5 Apr 12 18:30 raidard.pid
-rw-r--r-- 1 statd guest 5 Apr 12 18:30 rpc.statd.pid
-rw-r--r-- 1 root root 5 Apr 12 18:30 smbd.pid
-rw------- 1 root root 5 Apr 12 18:30 sm-notify.pid
-rw-r--r-- 1 root root 5 Apr 12 18:30 sshd.pid
-rw-r--r-- 1 root root 5 Apr 12 18:35 transmission-daemon.pid
-rw-r--r-- 1 root root 5 Apr 12 18:31 upnphttpd.pid
lrwxrwxrwx 1 root root 6 Apr 12 14:01 /var/run -> ../run
