BaJohn
Feb 15, 2016Virtuoso
OS 6.4.2 apache2 rewrite problem when using WordPress.
I have read https://community.netgear.com/t5/Using-your-ReadyNAS/OS-6-1-4-apache2-mod-rewrite-htaccess-problem/m-p/896062#M49808, but I still am confused, probably since that post refers to an earlie...
BaJohn
Feb 16, 2016Virtuoso
cont ...
discovered that there is a 'https.conf' file as well as a 'http.conf' file in the same folder - arggh I think I may have solved it.
(nobody seems to mention the secure version, but what the hell, I'm on a roll .....)
So do the same thing in that file, and no luck.
Reboot both the ReadyNAS and my PC, also clear the cache on my PC ... still no luck.
so it's still ANY HELP APPRECIATED - Please.
BaJohn
cont ... (for the benefit of others coming after me with the same problem)
I want to check (again) that I have the 'mod_rewrite' module loaded.
As I already know about using 'phpinfo', I check that and show the appropriate bit below.
Configuration apache2handler
| Apache Version | Apache/2.2.31 (Debian) |
| Apache API Version | 20051115 |
| Server Administrator | admin@localhost |
| Hostname:Port | 2002:4d64:64ad:e472:4694:fcff:fe6e:3848:443 |
| User/Group | admin(98)/98 |
| Max Requests | Per Child: 0 - Keep Alive: off - Max Per Connection: 100 |
| Timeouts | Connection: 300 - Keep-Alive: 5 |
| Virtual Server | Yes |
| Server Root | /etc/apache2 |
| Loaded Modules | core mod_log_config mod_logio mod_version prefork http_core mod_so mod_alias mod_auth_basic mod_auth_token mod_authn_file mod_authnz_external mod_authnz_ldap mod_authz_default mod_authz_groupfile mod_authz_host mod_authz_unixgroup mod_authz_user mod_autoindex mod_cgi mod_dav mod_dav_fs mod_deflate mod_dir mod_env mod_headers util_ldap mod_mime mod_negotiation mod_php5 mod_reqtimeout mod_rewrite mod_setenvif mod_ssl mod_status mod_privsep mod_authn_privsep |
I have no idea whether the other bits and pieces are right, but I do have the mod_rewrite module loaded.
So now off to check the internet some more ... this could be a long night.
