bvanaerde
Sep 04, 2015Aspirant
ownCloud 8.1.2 (rnxtras) fresh install failing
Did anyone manage to install ownCloud above version 8.1 on ReadyNAS R6? I'm getting some errors from the start. Owncloud was working well here until up to 8.0.X. So I decided to do a fresh install o...
WhoCares_
Sep 06, 2015Mentor
I just tested fresh installs and upgrades on RN102, RN204 and RN314. Worked in every case, so I have to assume it's something different that is causing the problems on your system. May well be related to SSL issues but then I don't even use a valid certificate on my test systems here and it's still working. If you have ssh access to your ReadyNAS enabled, can you send the output of
ls -al /apps/owncloud/web/config
-Stefan
- bvanaerdeSep 07, 2015Aspirant
Thanks for wanting to help out, Stefan.
root@readyNAS:~# ls -al /apps/owncloud/web/config total 296 drwxrwxrwx 1 admin admin 98 Sep 4 21:04 . drwxr-xr-x 1 admin admin 378 Sep 4 20:24 .. -rw-r--r-- 1 admin admin 258423 Sep 2 11:56 ca-bundle.crt -rw-rw---- 1 admin admin 197 Sep 4 21:04 config.php -rw-r--r-- 1 admin admin 31823 Sep 2 23:12 config.sample.php -rw-r--r-- 1 admin admin 225 Sep 2 11:56 .htaccess
The config.php file only contained the instanceid. Adding the trusted domains didn't help much, as the owncloud logfile doesn't seem to log everything. It doesn't show anything for today, but I have tried to access the homepage several times.
Can be useful to know:
- I am able to access the robots.txt through the browser while using https.
- I'm getting correct output on the terminal with: php /apps/owncloud/web/index.php.
- amc_oldsargeSep 09, 2015Guide
I too am having a problem with the latest version of OwnCloud from rxntras.
Here is my output:
root@NAS-Server04:/# ls -al /apps/owncloud/web/config total 296 drwxrwxrwx 1 admin admin 98 Sep 7 15:08 . drwxr-xr-x 1 admin admin 378 Sep 7 15:07 .. -rw-r--r-- 1 admin admin 258423 Sep 2 04:56 ca-bundle.crt -rw-r----- 1 admin admin 61 Sep 7 15:08 config.php -rw-r--r-- 1 admin admin 31823 Sep 2 16:12 config.sample.php -rw-r--r-- 1 admin admin 225 Sep 2 04:56 .htaccess
If you'd like to get on my server and test, I'd be willing to make it available to you. Just let me know that is the case.
Thanks!
Kyle
- bvanaerdeSep 14, 2015Aspirant
WhoCares_
Do you have enough information with this? Please ask, if you need anything else.
