bvanaerde
Sep 04, 2015Aspirant
ownCloud 8.1.2 (rnxtras) fresh install failing
Did anyone manage to install ownCloud above version 8.1 on ReadyNAS R6? I'm getting some errors from the start. Owncloud was working well here until up to 8.0.X. So I decided to do a fresh install o...
bvanaerde
Sep 07, 2015Aspirant
Thanks for wanting to help out, Stefan.
root@readyNAS:~# ls -al /apps/owncloud/web/config total 296 drwxrwxrwx 1 admin admin 98 Sep 4 21:04 . drwxr-xr-x 1 admin admin 378 Sep 4 20:24 .. -rw-r--r-- 1 admin admin 258423 Sep 2 11:56 ca-bundle.crt -rw-rw---- 1 admin admin 197 Sep 4 21:04 config.php -rw-r--r-- 1 admin admin 31823 Sep 2 23:12 config.sample.php -rw-r--r-- 1 admin admin 225 Sep 2 11:56 .htaccess
The config.php file only contained the instanceid. Adding the trusted domains didn't help much, as the owncloud logfile doesn't seem to log everything. It doesn't show anything for today, but I have tried to access the homepage several times.
Can be useful to know:
- I am able to access the robots.txt through the browser while using https.
- I'm getting correct output on the terminal with: php /apps/owncloud/web/index.php.
amc_oldsarge
Sep 09, 2015Guide
I too am having a problem with the latest version of OwnCloud from rxntras.
Here is my output:
root@NAS-Server04:/# ls -al /apps/owncloud/web/config total 296 drwxrwxrwx 1 admin admin 98 Sep 7 15:08 . drwxr-xr-x 1 admin admin 378 Sep 7 15:07 .. -rw-r--r-- 1 admin admin 258423 Sep 2 04:56 ca-bundle.crt -rw-r----- 1 admin admin 61 Sep 7 15:08 config.php -rw-r--r-- 1 admin admin 31823 Sep 2 16:12 config.sample.php -rw-r--r-- 1 admin admin 225 Sep 2 04:56 .htaccess
If you'd like to get on my server and test, I'd be willing to make it available to you. Just let me know that is the case.
Thanks!
Kyle
- bvanaerdeSep 14, 2015Aspirant
WhoCares_
Do you have enough information with this? Please ask, if you need anything else.
- bvanaerdeSep 15, 2015Aspirant
It looks like PHP 5.4 was the culprit.
I upgraded to PHP 5.6 using this guide, and afterwards Owncloud started up without problems.
- WhoCares_Sep 15, 2015Mentor
If you had the PHP add-on installed, that may indeed be the source of the problem.
My OwnCloud add-on doesn't require the PHP add-on to be installed for it requests all the needed PHP packages during install. So there's a chance that upgrading to PHP 5.6 fixed what may have been broken in the original PHP install by the PHP add-on. I ran a lot of tests on my systems and didn't find any problem using the method without the PHP add-on. I think I'll need to investigate what the official PHP add-on is doing different and maybe even provide a PHP 5.6 installer for those who aren't comfortable with the command line.
Thanks for the information.
-Stefan
