bvanaerde
Sep 04, 2015Aspirant
ownCloud 8.1.2 (rnxtras) fresh install failing
Did anyone manage to install ownCloud above version 8.1 on ReadyNAS R6? I'm getting some errors from the start. Owncloud was working well here until up to 8.0.X. So I decided to do a fresh install o...
WhoCares_
Sep 15, 2015Mentor
If you had the PHP add-on installed, that may indeed be the source of the problem.
My OwnCloud add-on doesn't require the PHP add-on to be installed for it requests all the needed PHP packages during install. So there's a chance that upgrading to PHP 5.6 fixed what may have been broken in the original PHP install by the PHP add-on. I ran a lot of tests on my systems and didn't find any problem using the method without the PHP add-on. I think I'll need to investigate what the official PHP add-on is doing different and maybe even provide a PHP 5.6 installer for those who aren't comfortable with the command line.
Thanks for the information.
-Stefan
bvanaerde
Sep 16, 2015Aspirant
I was indeed using Poussin's PHP addon.
I found out by installing Owncloud on my desktop (which has a LAMP with PHP v5.4 as well). There, it worked, but it gave cURL errors when trying to install the Gallery+ app for Owncloud.
cURL error 60: SSL certificate problem: unable to get local issuer certificate
This got me thinking about the PHP version.
Even though 5.4 should work with the latest Owncloud, I guess there's a module that's outdated in the PHP addon.
- WhoCares_Sep 16, 2015Mentor
The certificates are indeed outdated on the ReadyNAS but that's totally separate from PHP. Now, there's of course a chance that the updated PHP 5.6 from dotdeb also installs updated certificates in it's wake. Do you have a log of the packages that got installed while installing the PHP 5.6 version from dotdeb?
-Stefan
- bvanaerdeSep 16, 2015Aspirant
apt-get log:
Start-Date: 2015-09-16 00:09:29
Commandline: apt-get -y purge owncloud
Purge: owncloud:amd64 (8.0.4-rnx1)
End-Date: 2015-09-16 00:09:56
Start-Date: 2015-09-16 00:11:25
Commandline: apt-get install php5
Install: libvpx1:amd64 (1.1.0-1, automatic), libt1-5:amd64 (5.1.2-3.6, automatic)
Upgrade: php5-sqlite:amd64 (5.4.4-14+deb7u9, 5.6.13-1~dotdeb+7.1), libapache2-mod-php5:amd64 (5.4.4-14+deb7u9, 5.6.13-1~dotdeb+7.1), php5-mysql:amd64 (5.4.4-14+deb7u9,
5.6.13-1~dotdeb+7.1), php5-common:amd64 (5.4.4-14+deb7u9, 5.6.13-1~dotdeb+7.1), php5-curl:amd64 (5.4.4-14+deb7u9, 5.6.13-1~dotdeb+7.1), php5-mcrypt:amd64 (5.4.4-14+de
b7u9, 5.6.13-1~dotdeb+7.1), php5:amd64 (5.4.4-14+deb7u9, 5.6.13-1~dotdeb+7.1), php5-cli:amd64 (5.4.4-14+deb7u9, 5.6.13-1~dotdeb+7.1), php5-gd:amd64 (5.4.4-14+deb7u9, 5
.6.13-1~dotdeb+7.1), php5-imagick:amd64 (3.1.0~rc1-1+b2, 3.1.2-2~dotdeb+7.1), php5-intl:amd64 (5.4.4-14+deb7u9, 5.6.13-1~dotdeb+7.1)
Remove: php5-xcache:amd64 (2.0.0-4)
End-Date: 2015-09-16 00:16:01 - WhoCares_Sep 16, 2015Mentor
Doesn't look like any certificate related stuff got installed, so it might well be that the newer PHP5-curl module handles SSL a bit more relaxed than the one in PHP 5.4.44. I'll check.
-Stefan
Ok, thanks.
As you can see, xcache is removed, as it isn't included in the repository that I added. If you are considering to make a PHP 5.6 module, it might be useful to include this as well.
No need since PHP 5.6 includes a better caching system, formerly provided by the PHP5-zendopcache module. You may want to manually install PHP5-yac, however, to provide some additional caching for variables.
-Stefan
