Jarkod
Aug 24, 2014Guide
Owncloud on different port
I've managed to install Owncloud on RN102 with 6.1.9 RC11 OS and configured it to force https connections. The problem is Owncloud uses the 443 port, the same as FronView does. I'd like Owncloud to us...
Jarkod
Aug 25, 2014Guide
I've installed Owncloud in ssh console because I couldn't do it in FV:
apt-get update
apt-get install mysql-server
apt-get install phpr6
apt-get install phpmyadmin php5-mysql
apt-get install owncloud (it was v6)
then I downloaded the v7 from the Owncloud website, deleted the content of the /apps/owncloud/web catalogue and extracted the v7 archive into it. I finished the configuration in the web browser.
So, I'm using the v7 of the Owncloud but I can't tell you what apps because I don't know how to check it. Anyway, if there are any, there're only those delivered from the Owncloud website.
apt-get update
