Jarkod
Aug 24, 2014Guide
Owncloud on different port
I've managed to install Owncloud on RN102 with 6.1.9 RC11 OS and configured it to force https connections. The problem is Owncloud uses the 443 port, the same as FronView does. I'd like Owncloud to us...
Jarkod
Aug 25, 2014Guide
super-poussin wrote: owncloud is also working on http tcp 7115
Yes I know but what I'm after is separating FV and OwnCloud. I don't want them to use the same port. If there's a way to prevent Owncloud from using 443 port and use 7115 for https connection, that's ok with me.
