zennit
Feb 24, 2012Aspirant
perl issues on duo
trying to install gitolite on my readynas duo which uses perl but getting Can't locate English.pm how would I go about adding this to perl? Do I have to apt-get some modules?
WhoCares_
Feb 24, 2012Mentor
You could try re-installing the perl-modules package using apt-get. While it is being reported as being installed it was heavily stripped afterwards before so the firmware on the ReadyNAS only contains a subset of the originally included modules.
-Stefan
-Stefan
