TWfromSWD
Nov 06, 2017Aspirant
ReadyNAS 104 munin/perl problem
Hi there
I'm using Munin for monitoring my ReadyNAS 104 but after the last Firmware update to 6.9.0 my munin node stopped working. When I try to start one of the Munin plugins with munin-run I get the following message:
Can't locate English.pm in @INC (you may need to install the English module) (@INC contains: /etc/perl /usr/local/lib/arm-linux-gnueabi/perl/5.20.2 /usr/local/share/perl/5.20.2 /usr/lib/arm-linux-gnueabi/perl5/5.20 /usr/share/perl5 /usr/lib/arm-linux-gnueabi/perl/5.20 /usr/share/perl/5.20 /usr/local/lib/site_perl) at /usr/share/perl5/Munin/Common/Defaults.pm line 9. BEGIN failed--compilation aborted at /usr/share/perl5/Munin/Common/Defaults.pm line 9. Compilation failed in require at /usr/sbin/munin-run line 31. BEGIN failed--compilation aborted at /usr/sbin/munin-run line 31.
So I'm thinking it has something to do with Perl missing some Modules. Unfortunately the new version of the ReadyNAS firmware seems to use a variation of perl that isn't supportet anymore by the regular debian sources cause when I try to
apt-get install perl-modules
I get the following conflicts
Reading package lists... Done
Building dependency tree
Reading state information... Done
You might want to run 'apt-get -f install' to correct these:
The following packages have unmet dependencies:
dpkg : Breaks: libapache2-mod-php5 (< 5.6.4+dfsg-3~) but 5.4.35-0+deb7u2 is to be installed
libdbd-mysql-perl : Depends: perlapi-5.14.2 but it is not installable
libdbi-perl : Depends: perlapi-5.14.2 but it is not installable
libgd2-xpm : Depends: libfontconfig1 (>= 2.9.0) but it is not going to be installed
Depends: libfreetype6 (>= 2.2.1) but it is not going to be installed
Depends: libjpeg8 (>= 8c) but it is not going to be installed
liblist-moreutils-perl : Depends: perlapi-5.14.2 but it is not installable
libsocket6-perl : Depends: perlapi-5.14.2 but it is not installable
libxcb1 : Depends: libxau6 but it is not going to be installed
openjdk-6-jre-headless : Depends: libjpeg8 but it is not going to be installed
perl : Depends: perl-base (= 5.14.2-21+deb7u2) but 5.20.2-3+deb8u9 is to be installed
perl-base : Breaks: perl (< 5.20.0~) but 5.14.2-21+deb7u2 is to be installed
perl-modules : Breaks: perl (< 5.20.2~) but 5.14.2-21+deb7u2 is to be installed
php5-gd : Depends: libfreetype6 (>= 2.2.1) but it is not going to be installed
php5-snmp : Depends: libsnmp15 (>= 5.4.3~dfsg) but it is not installable
tzdata-java : Depends: tzdata (= 2015f-0+deb7u1) but 2017b-0+deb8u1 is to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).Is there anything I can do about this? Is there a munin version that works with the new firmware or is it possible to install older versions of the missing perl modules? I don't want to break the ReadyNAS OS but also I don't want to lose munin monitoring.
Now that is strange. The Munin node on my ReadyNAS suddenly started working again. Without me doing anything to the system. No more error messages with munin-run. And the graphs show up on the server.
1 Reply
- TWfromSWDAspirant
