zennit
Feb 24, 2012Aspirant
perl issues on duo
trying to install gitolite on my readynas duo which uses perl but getting Can't locate English.pm how would I go about adding this to perl? Do I have to apt-get some modules?
zennit
apt-get --reinstall install perl-modules
Reading Package Lists... Done
Building Dependency Tree... Done
Reinstallation of perl-modules is not possible, it cannot be downloaded.
You might want to run `apt-get -f install' to correct these:
The following packages have unmet dependencies:
php5-ldap: Depends: libsasl2 (>= 2.1.19.dfsg1) but it is not installable
W: Couldn't stat source package list http://www.readynas.com readynas/ Packages (/var/lib/apt/lists/www.readynas.com_packages_readynas_Packages) - stat (2 No such file or directory)
W: Couldn't stat source package list http://archive.debian.org sarge/main Packages (/var/lib/apt/lists/archive.debian.org_debian_dists_sarge_main_binary-sparc_Packages) - stat (2 No such file or directory)
W: Couldn't stat source package list http://archive.debian.org sarge/contrib Packages (/var/lib/apt/lists/archive.debian.org_debian_dists_sarge_contrib_binary-sparc_Packages) - stat (2 No such file or directory)
W: Couldn't stat source package list http://archive.debian.org sarge/non-free Packages (/var/lib/apt/lists/archive.debian.org_debian_dists_sarge_non-free_binary-sparc_Packages) - stat (2 No such file or directory)
W: You may want to run apt-get update to correct these problems
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
