zennit
Feb 24, 2012Aspirant
perl issues on duo
trying to install gitolite on my readynas duo which uses perl but getting Can't locate English.pm how would I go about adding this to perl? Do I have to apt-get some modules?
WhoCares_
Feb 24, 2012Mentor
The "couldn't stat source" messages suggest that something is wrong with the DNS settings on your ReadyNAS.
-Stefan
Edit: Yes, you should run apt-get update otherwise the system has no info whatsoever about where to actually find modules. And since apt-get update only updates the local database but doesn't install anything, it's safe to run.
-Stefan
