zennit
Feb 24, 2012Aspirant
perl issues on duo
trying to install gitolite on my readynas duo which uses perl but getting Can't locate English.pm how would I go about adding this to perl? Do I have to apt-get some modules?
mdgm-ntgr
Feb 24, 2012NETGEAR Employee Retired
Don't think so. That might break things. I'd probably try installing WhoCares?'s add-on then if what you want to install still won't install attempt to install the perl-modules again.
If you prefer you could try "apt-get install php5-ldap" and see what output that produces.
