zennit
Feb 24, 2012Aspirant
perl issues on duo
trying to install gitolite on my readynas duo which uses perl but getting Can't locate English.pm how would I go about adding this to perl? Do I have to apt-get some modules?
mdgm-ntgr
Feb 24, 2012NETGEAR Employee Retired
If you have a current version of his add-on you shouldn't be able to disable it, I think. What version of the add-on do you have?
