zennit
Feb 24, 2012Aspirant
perl issues on duo
trying to install gitolite on my readynas duo which uses perl but getting Can't locate English.pm how would I go about adding this to perl? Do I have to apt-get some modules?
mdgm-ntgr
Feb 24, 2012NETGEAR Employee Retired
So you have that module listed and also found by dpkg command I mentioned above?
Can you also try this:
dpkg -l | grep libsasl
