zennit
Feb 24, 2012Aspirant
perl issues on duo
trying to install gitolite on my readynas duo which uses perl but getting Can't locate English.pm how would I go about adding this to perl? Do I have to apt-get some modules?
WhoCares_
Feb 24, 2012Mentor
The php5-ldap thingy is a "known issue" but not the source of the current problem, really.
Back on topic: According to my crystal ball (package search on Debian ;)) the English.pm file should be part of the the perl-modules package. Or at least it is with newer Perl versions. What does
tell you?
-Stefan
dpkg -S English.pm
tell you?
-Stefan
