zennit
Feb 24, 2012Aspirant
perl issues on duo
trying to install gitolite on my readynas duo which uses perl but getting Can't locate English.pm how would I go about adding this to perl? Do I have to apt-get some modules?
zennit
nas-C7-F3-68:~# apt-get install --reinstall perl-modules
Reading Package Lists... Done
Building Dependency Tree... Done
0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 78 not upgraded.
Need to get 2310kB of archives.
After unpacking 0B of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 http://www.readynas.com readynas/ perl-modules 5.8.8-7.infrant2 [2310kB]
Fetched 2310kB in 9s (253kB/s)
(Reading database ... 15165 files and directories currently installed.)
Preparing to replace perl-modules 5.8.8-7.infrant2 (using .../perl-modules_5.8.8-7.infrant2_all.deb) ...
Unpacking replacement perl-modules ...
dpkg: perl-modules: warning - conffile `etc/Net' is not a plain file or symlink (= `/etc/Net')
Setting up perl-modules (5.8.8-7.infrant2) ...
dpkg: perl-modules: warning - conffile `/etc/Net' is not a plain file or symlink (= `/etc/Net')
