WhoCares_
Jun 12, 2011Mentor
phpMyAdmin (3.4.10.1)
phpMyAdmin 3.4.10.1
Description:
phpMyAdminis a software tool written in PHP intended to handle the administration of MySQL over the World Wide Web. phpMyAdmin supports a wid...
WhoCares_
Mar 09, 2012Mentor
Thunderoid
Oct 03, 2015Aspirant
Hey!
Thanks for supplying all these addons to expand the capabilities of the ReadyNAS :)
Will this addon also require the mySQLon addon (can't find x86 version available anymore..?) or the ReadyNAS Photos II to be active, or is there some other better way to activate MySQL? (Readynas Ultra 4, RAIDiator 4.2.27)
I recently did a factory reset on my Ultra 4 which was running owncloud 6 (PHP 5.4.45 and Owncloud6 bought from your site), but just for my personal use.
Intend to extend to more family members and wanted to start from scratch for most updated version and dedicated to Owncloud..
So bought owncloud 8 install, and found it recommends MySQL for more than one user - so also got this phpMyAdmin installer.
From factory reset added these: SSH enable, php, PHPMyAdmin, owncloud.
Found that there are no files under /var/run/mysqld - no mysqld.sock
Neither tcp or socket will let me connect, or switching between cookie and config authentication. Saved after applying each time.
Should I choose to use SSL (will the readynas support it?)
The error messages at "https://192.168.1.105/phpmyadmin/index.php" are either;
- config authentication: any user/pass combination results in: "#2002 Can not login to the MySQL server"
- cookie authentication or socket connection: before any login "Can not connect: invalid settings. phpMyAdmin tried to connect to the MySQL server, and the server rejected the connection. You must check the host (host), username (username) and password (password) in the configuration and make sure that they correspond to the information received from the MySQL server administrator." (translated back from my native language)
From reading around I presume I should use these configuration settings, but probably after getting mySQL active?
host: localhost
socket: /var/run/mysqld/mysqld.sock
Use SSL: check
Connection type: socket
Authentication type: config
User for config authentication: root (or admin ?)
pass: 'leave blank'
accept login as root: check
Rest of settings left blank/default ?
Or are there any other settings that must be adjusted correctly for the ReadyNAS Ultra 4 and Owncloud combo ?
