michelefaccini
Sep 28, 2014Aspirant
PhpMyAdmin Bundle (R4x86)
Hi all, I've just bought this bundle to upgrade my PHP and phpMyAdmin installation on my ReadyNas Ultra 2 Plus. Because I didn't want to edit manually the conf.inc.php file to set up phpMyAdmin,...
WhoCares_
Sep 28, 2014Mentor
michelefaccini wrote: Because I didn't want to edit manually the conf.inc.php file to set up phpMyAdmin, I accessed the automatic setup script from the browser (with https://192.168.0.2/phpmyadmin/setup/index.php).After I set up my configuration, a new config.inc.php file should have been saved in the config folder (folder that I created manually under usr/share/phpmyadmin) but the folder is empty !
Did you press the "Save" button twice? You have to press it once when saving the current MySQL Server config and the second time to save the complete config back to a file. Also, did you set the access permissions correctly in the PhpMyAdmin config pane within Frontview before getting to the configuration?
What made you think you would need to create a directory manually and why do you think you got the correct location and where should PhpMyAdmin know from that you created the directory and that it should save your settings there? In reality, the config is saved to the /var/lib/phpmyadmin directory - but again, only if you really saved
it.
michelefaccini wrote: So If I'm not wrong the only way to configure phpMyadmin is to create manually a config.inc.php file which has to be saved under conf.d folder (which is under etc/phpmyadmin).
Is it right...or am I missing something ?
I'd say you're missing something.
-Stefan
