michelefaccini
Sep 28, 2014Aspirant
PhpMyAdmin Bundle (R4x86)
Hi all, I've just bought this bundle to upgrade my PHP and phpMyAdmin installation on my ReadyNas Ultra 2 Plus. Because I didn't want to edit manually the conf.inc.php file to set up phpMyAdmin,...
michelefaccini
What I did :
1/ I installed the add-ons (without uninstalling the previous php and phpMyAdmin addons).
2/ I accessed the Frontview and set the Protection up to open (I also tried to Admin only) in the pane.
3/ I clicked on 'Configure PhpMyAdmin'.
4/ I chose 'new server' and set it up.
5/ I chose 'save' and got the following message :
Configuration saved.
Configuration saved to file config/config.inc.php in phpMyAdmin top level directory, copy it to top level one and delete directory config to use it.
That's why I thought I had to create the config folder by myself....there wasn't any....
Actual situation : I can access phpMyAdmin with https://192.168.0.2/phpmyadmin/index.php,I can see that my databases are listed but when I choose to click something on the page nothing happens.
My website is functioning....so the server and my databases are ok but the phpMyAdmin interface is not communicating
