michelefaccini
Sep 28, 2014Aspirant
PhpMyAdmin Bundle (R4x86)
Hi all, I've just bought this bundle to upgrade my PHP and phpMyAdmin installation on my ReadyNas Ultra 2 Plus. Because I didn't want to edit manually the conf.inc.php file to set up phpMyAdmin,...
WhoCares_
Sep 30, 2014Mentor
Your problem is that by default the MySQL server on the ReadyNAS only listens on the 127.0.0.1 (localhost) interface. Or in other words: it doesn't listen on the external interfaces that are used to attach your ReadyNAS to your local network. Thus you need to change the MySQL configuration before you can use MySQL Workbench or similar tools. To change MySQL's behavior, use an SSH shell and edit the file /etc/mysql/my.cnf. Look for this line:
and change it to
Then restart the MySQL server. The easiest way for stopping/starting MySQL would be to use the MySQLOn add-on.
-Stefan
bind-address = 127.0.0.1
and change it to
bind-address = 0.0.0.0
-Stefan
