oo7cable
Apr 25, 2019Aspirant
Postgresql installation - HELP!!!
Hello everyone - complete noob here. I bought a readyNAS 214 to use on a film I'm editing. I run Davinci Resolve 15 and I'm trying to set up a collaborative workflow. Like this - https://www.qnap.com...
- Apr 26, 2019
I think you'll need to install it directly from ssh. https://kb.netgear.com/30068/ReadyNAS-OS-6-SSH-access-support-and-configuration-guides
There are some instructions here: https://www.postgresql.org/download/linux/debian/ But they might not help you much if you don't already know linux.
Apr 26, 2019Guru - Experienced User
oo7cable
Apr 26, 2019Aspirant
I don't know anything about Linux.. but nows a good time to learn!
I'll manage from here - this is exactly what I needed thanks!!!
- SandsharkApr 26, 2019Sensei
Just make sure you don't create the database on the OS volume. It will likely fill up, giving you all kinds of grief.
