BaJohn
Feb 21, 2016Virtuoso
Printing a file from the shell.
I can see no way of setting up access to a printer from the admin page. I can see no apps which will help setup a printer. Within SSH the 'lp' command is disabled. Whilst working, I get fed up ...
- Mar 16, 2016
BaJohn wrote:
mdgm wrote:RNXtras has an AirPrint app: https://rnxtras.com/addons/rnairprint-readynas-6-all
Have you tried that?
Oh that sounds interesting ...
My printers support airprint.
Can you just explain something to me re the apps.
If it is listed in the pages accessible from the ReadyNAS admin page => Apps etc, does that mean that they are approved/tested by Netgear.
Equally if it is an 'outside' apps, does that mean it is NOT approved ny Netgear?
Thanks for the prompt I will give it a go and respond on this post.
Okay ... had a look at the app and unhappy with more messing about.
Everything I try to do always seems to get bogged down somwhere, somehow:)
I NOW have the access to most of the ReadyNAS from my PC via Samba (I believe) in the Network folder.
So I will close this post.
ATB
BaJohn
Feb 23, 2016Virtuoso
BaJohn
Mar 16, 2016Virtuoso
ATB
