davidereitano
Aug 15, 2017Aspirant
Problems syncing entire Dropbox
Hello. I am experiencing some problems with Dropbox sync on my two RN104 6.7.5 They're both configured with the same Dropbox account for syncing the entire public folder on the "Dropbox" share. Fi...
Marty_M
Aug 17, 2017NETGEAR Employee Retired
Hello davidereitano,
It does appear that you are having trouble with ReadyDrop feature of the NAS. May I verify how is the sync direction setup? Is it possible to provide a screen shot of the error you are explain. Firmware version 6.8.0 is already release you may try this version and check if it will help with the concern.
Welcome to the community!
Marty_M
NETGEAR Community Team
- davidereitanoAug 21, 2017Aspirant
Hello.
i have updated both 104 with latest firmware (6.8.0) but nothing changed.
On one of them i disabled Dropbox, deleted every file in share, copied from pc the entire folder and reactivated service.After some hours, it began to upload files that are already present in dropbox.
- Marty_MAug 22, 2017NETGEAR Employee Retired
Can you provide a screenshot of the dropbox setting. There is a possibility that the share is set to sync with the dropbox folder.
Marty_M
