davidereitano
Aug 15, 2017Aspirant
Problems syncing entire Dropbox
Hello. I am experiencing some problems with Dropbox sync on my two RN104 6.7.5 They're both configured with the same Dropbox account for syncing the entire public folder on the "Dropbox" share. Fi...
Marty_M
Aug 27, 2017NETGEAR Employee Retired
Hello davidereitano,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance. If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Marty_M
NETGEAR Community Team
davidereitano
Aug 29, 2017Aspirant
Hello.
Here's my configuration.
I've done some more changes (including a complete reset of the system and hard disks) but the problem persists.
- Marty_MAug 29, 2017NETGEAR Employee Retired
Bidirectional or 2 way sync meaning changes made on the dropbox folder will be updated on the NAS folder and vice versa. There is an option where you can set the sync direction to "Download changes from cloud storage only" meaning only changes made on the dropbox folder will be backup on the NAS. I believe this is the goal you want to achieve based on your initial post.
Marty_M
NETGEAR Community Team- davidereitanoAug 29, 2017Aspirant
Yes, Bidirectional is exactly what i want.
In fact, as i told, if a file is already in my Dropbox and correctly downloaded on every PC or NAS, the RN104 keeps uploading it as it isn't present.
- Marty_MAug 30, 2017NETGEAR Employee Retired
For the first problem how do you check or verify that dropbox syncing some file (4 zips over 2gb each) even though there were no changes are made on both sides.
As or the second problem do you mean you are transferring a file from folder to another folder on the Readynas device? are these folder are set to sync to dropbox folder?
Marty_M
