igor_dulatov
Nov 01, 2009Aspirant
PS3 Media Server for ReadyNAS PRO
I have made addon PMS for readynas pro. it support transcoding in realtime (mkv can play at PS3). Addon include java, mplayer, mencoder, ffmpeg, tsmuxer and PMS. If anybody want to test it - downloa...
Ushman
Dec 30, 2009Aspirant
Hi,
I am running 4.2.8 on a ReadyNas Pro Pioneer.
I installed this add-on and tried to use it. The PS3 found the add-on right away and I was able to view all the files on the NAS. However when I tried to play a 720p mkv file, the add-on was not capable of transcoding it. It took about 10-12 seconds and then I got a message saying the data is corrupt. I know the data is not corrupt and tried another file to be sure. Any suggestions? I tried the transcode folder as well and still no luck.
I did try this on a 8gb mkv file (Lethal weapon 1080p mkv) and it did work fine, so it seems to work on some files. I watched the first 7 minutes and no stuttering problems at all. I look forward to testing some more mkv files.
I think this is a brilliant add-on however I am not sure the ReadyNas has enough horsepower to keep this working properly. I would be happy to continue testing this to help. Will this add-on tax the processor in the NAS, increase heat?
Also, I did not have any problems with extra shares being created. It would be helpful if you could change the language to english under the settings folder.
Ushman
Ushman
