igor_dulatov
Nov 01, 2009Aspirant
PS3 Media Server for ReadyNAS PRO
I have made addon PMS for readynas pro. it support transcoding in realtime (mkv can play at PS3). Addon include java, mplayer, mencoder, ffmpeg, tsmuxer and PMS. If anybody want to test it - downloa...
linkup1
Dec 31, 2009Aspirant
Ushman wrote: Hi,
I am running 4.2.8 on a ReadyNas Pro Pioneer.
I think this is a brilliant add-on however I am not sure the ReadyNas has enough horsepower to keep this working properly. I would be happy to continue testing this to help. Will this add-on tax the processor in the NAS, increase heat?
I have a Pro on order and will be putting 2TB Hitachis and more RAM in it. When you wonder if the Pro is adequate or not for the job, do you have fast or slow drives, and have you added RAM?
I will be using a PS3 for one home theater, but need a solution for the other home theater. Was looking at the Popcorn C-200.
They cost more than a PS3 and I don't need a second PS3 so I want an alternative solution so I have two choices in products.
Thanks,
Lew
