igor_dulatov
Nov 01, 2009Aspirant
PS3 Media Server for ReadyNAS PRO
I have made addon PMS for readynas pro. it support transcoding in realtime (mkv can play at PS3). Addon include java, mplayer, mencoder, ffmpeg, tsmuxer and PMS. If anybody want to test it - downloa...
linkup1
Jan 01, 2010Aspirant
Ushman wrote: Lew,
The PS3 is an excellent choice for media streamer, I have two of them. I am also looking for an additional product and did look at the new popcorn hour c-200 as well. The c-200 is way overpriced at this point for me as I am in Canada and would have to pay almost $400 to get one shipped and then fork over another $150 for a blu-ray drive.
If you don't need the blu-ray drive, you should consider the Western Digital WD TV Live as I have read many good reviews on it and it is powered by the new Sigma chipset. And try to hold out until the specs for the new Boxee Box are released here in January (http://www.boxee.tv/box).
Regardless I think I will be adding some RAM and look forward to using this add-on rather than transcoding all the mkv files I download.
Glad to hear it works well in the streamer capacity. It would be handy to have a blu-ray device for the second home theater which was part of the reason I chose a PS3 for one home theater. Seemed like the game part was almost free considering the value of the blu-ray drive in it.
If you got the C-200, you wouldn't need to get the drive for it right away. You could use the streaming feature first and then s BD drive later.
What value do you see the C-200 having over a PS3?
Lew
